DRL Fogs
I am getting some HID headlights and I do not want to be running the headlights as Day time running lights anymore. Is there a way i can make the fog lights DRL instead?
theres a relay for everything in the hummer. get a manual and look over the diagram . you can probably figure it out
After a whole bunch of reading it seems it may be more difficult than i originally thought.
i was bz the other day, so now i took a look . you ,,,first you can just pull the drl fuse and kill them. i did that. end the story. or
second you would need to find and cut the wire from the drl relay to headlights and do the diode trick from drl to fog relay. thats ez. cutting the wire? gotta dig it out. its there! |
