-   -   CTIS Blow Out (https://www.hummerforums.com/forum/private-sale-trade-classifieds-10/ctis-blow-out-27241/)
Dharpe82 Mar 15, 2012 09:03 AM
CTIS Blow Out
Yesterday I went to deflate my front tires and as soon as I hit deflate it started letting out the air at a rapid pace. I disconected the front tires and filled them back up. When I reconnect either of the front tires the air flows out of the manifold. Any idea how I can fix this?
Dharpe82 Mar 15, 2012 01:54 PM
This is only on the front tires. The rear tires are still connected to the system and are holding air.
3hummers Mar 16, 2012 12:07 AM
May need to rebuild the manifold. Sounds like you may need new seals. Where is the air leaking from the manifold?
Dharpe82 Mar 16, 2012 08:32 AM
It is leaking out of the outlet on the side of the manifold that allows the air to escape. It is just free flowing but only allowing the front tires to escape. The rear tires still work fine.
Dharpe82 Mar 16, 2012 11:28 AM
OK I found out the exact name for the part. It is coming out of the Dust Excluder, part number 5935430. As soon as I plug the front tires back into the system it just free flows out of it.
Dharpe82 Mar 19, 2012 09:40 AM
I took the manifold apart and all of the valves, cleaned and oiled everything and now it works great! There was a few small peices of rust from the lines in the center valve that deflates the tires. It was holding the rubber flapper inside open. The last person that took it apart used a vice grip and gnared it up.
