Coolant Problem
Hi guys. Wondering if you can help me. I havea 2003 H2. Its loosing coolant. Havent found from where yet, but it needs topping up every 2 days. Also, the expansion tank looks a bit browny.
Any common faults or things i can check? Iv had a search through the forum but not found a difinitive answer.
Jay
Jay
I also have an 03 H2, but I have not had any coolant leakage......yet. Mine is also a little brown looking but it has always been like that. If its not dripping out on the ground, it could be leaking into the combustion chamber and exiting out the back as vapor. Lets hope its not that, it would mean the head gaskets may be blown...ouch! I'll also ask around.
Well, slightly good part is that its leaving puddles on the floor. But its a strange leak. If you park it, it doesnt always leak, then other times it does badly. Im going to have to wait for it to leak and then try hunt it down i think, not had the chance to yet. I was mostly concerned about the browny looking expansion tank.
Jay
Jay
ORIGINAL: H2 Jay
Jay
Jay
A new water pump would be my guess as well. They can leak somedays and be fine the next. Cold weather will make them leak more often. The other thing I would check is to make sure the transmission fluid is not overfilled from coolant entering the trans from a bad radiator trans cooler going bad.
H2Miami
Jul 27, 2015 07:59 PM
