Coolant leak help
Old Jan 24, 2009 | 01:56 PM
hummerray's Avatar
Default RE: Coolant leak help
HI All,
You'll be pleased to know that my truck is functional once again - leak bypassed and running well - well sort of! Since the coolant leak was fixed I now have an issue with the transmission. Sometimes it sticks in first gear - as if the computer is confused. Does anyone know if this could be related to disconnecting the batteries for too long any suggestions?
Old Jan 25, 2009 | 05:39 AM
h1rider's Avatar
hello there. you have to check the odometer.if the odometer does not work, check the speed sensor,in the transmission.
to check the sensor for continuity.sorry for my English.
Old Jan 25, 2009 | 09:49 AM
hummerray's Avatar
Hi,
Thanks. I will check the sensor - perhaps just needs a clean. Will keep you posted.
Thanks Again.
Old Feb 14, 2009 | 07:53 AM
hummerray's Avatar
Hey guys,
Thought I would let you know that after cleaning the speed sensors, the truck still won't shift properly! Computer says error 85 and 86 which both are to do with the sensors! Manual says if not the sensors then a whole list of other problems could be! Anyone had any experience like this before? - I guess I should open a new blog as this one's getting long!
Old Feb 14, 2009 | 09:05 AM
The two issues aren't related.
Old Feb 15, 2009 | 05:51 AM
h1rider's Avatar
Talking speed sensor
hello there.well i had this 4 months problems trying to find the problem in my trans.first i change the filter,no good,then i checked the fuses,all good.so i checked the speed sensor and bingo!that was the problem.did you get the trans. wet? because if the speed sensor get wet,does not work properly.check for continuity between the contacts.
change trans filter.
check the speed sensor fuse.
http://flashoffroad.com/Maintenance/...ansmission.htm
hope this will help you.
sorry for the english.
Songman
Feb 6, 2011 04:44 PM
mikecabo
Jan 27, 2011 03:39 PM
swenski71
Sep 20, 2010 10:31 PM
jacaron
Jun 2, 2009 05:40 PM
dizzy
Apr 22, 2008 09:34 PM
