Confirm Rim Fitment
Old Mar 9, 2014 | 04:57 PM
JimyYeags's Avatar
Default Confirm Rim Fitment
HI Guys-
Thinking about picking up a set of rims for the Hummer as a spare.
Can someone confirm if these will fit an 06 Hummer H3?
4 New 16x8 12 Offset 6x139 7 Unique 297 Black Wheels Rims | eBay
Thanks!
Old Mar 9, 2014 | 05:51 PM
6-139 is the correct bolt pattern. Do whatever you want to do with the size/offset.
http://www.boltpatternguide.net/Humm..._Patterns.html
Old Mar 10, 2014 | 10:53 AM
Bunger's Avatar
I'd be concerned about the center bore. I don't see it listed anywhere.
Wheels for a H3 need a center bore diameter of 101mm to locate correctly on the hub.
Any smaller diameter and it will not fit.
And you also need 5.5" or less backspace to clear rotors & calipers. Offset doesn't tell the whole story.
Read this: https://www.hummerforums.com/forum/h...uestion-30710/
Old Mar 10, 2014 | 05:50 PM
I did a little more research on the H3 factory rim (2006-2010) specs:
16X7.5
6-127
38 Offset
100 (actual 100.6) Center Bore
https://detroitwheelandtire.com/humm...2009-2010.html
06h3nc
May 6, 2013 12:39 AM
firefighter1133
Apr 9, 2012 07:03 AM
CodyB
May 21, 2011 09:11 PM
panamera
Jun 9, 2009 09:48 PM
HueyIII
Mar 27, 2008 07:54 AM
