Computer audio system vs Brand name audio system
So I found this while brousing for a new head unit and I thought that if anyone here has not seen this that it would be worth taking a look at also note that they do have better computer systems out there now than the one that was used in this build.
also what do you all think, would there be anyone willing to go this route or stick to the regular name brand style of system. IMOP this system would give you a greater array of ablitites you can hook up a WI-FI connector to this and really anything that you can think of doing with a computer you can just about do with this. http://www.mp3car.com/vbulletin/show...-computer.html In-dash Computer Install in a 2006 HUMMER H3 Why? After reading all the great things other folks were doing in this forum I found myself unsatisfied by OEM and aftermarket nav and entertainment solutions. Some of the advantages of building this system include:
Intel Core Duo processor iBase MB899 mini-ITX motherboard DSATX automotive power supply for motherboard DS12V automotive power supply for amp Xenarc 7” LCD touchscreen 700TSV Mechatroniks chassis Alpine Sirius Radio tuner SIR-ALP1 with MithJS interface board Peripheral GMAH24B for retaining OnStar Phidget encoder (for volume knob control) Volume knob from stock head unit Backup camera GlobalSat USB GPS antenna Seagate 100GB 2.5” hard drive Software: Windows XP Pro Road Runner - Thanks Guino! CFX skin as a base - Thanks b8bboi and Proximo! iGuidance TOPO! The rig: http://home.comcast.net/~jeff.wilder...r/DSC00029.JPG http://home.comcast.net/~jeff.wilder/h3puter/mud1.JPG These two pictures show the completed install. Note the volume knob lifted from the original head unit, where it was used for tone control. The rubberized texture and color of the knob matches the other knobs in the cabin, such as the A/C and vent position knobs. I was also able to perfectly match the color and texture of the screen bezel with the plastic surrounding the A/C vents at the top of the picture. http://home.comcast.net/~jeff.wilder...r/IMG_3495.JPG Here are some screen caps of the various functions: The startup screen. In the upper right corner is the clock and below that, “ONLINE” illuminates when I’m in range of my home wireless network. The icon on the bottom right is a button for synchronizing with my home computer. http://home.comcast.net/~jeff.wilder/h3puter/menu.jpg Selecting the WEATHER button above takes you to the current weather screen. It is updated automatically if online. http://home.comcast.net/~jeff.wilder...er/weather.jpg It also features a 5-day forecast screen. http://home.comcast.net/~jeff.wilder/h3puter/5day.jpg On the main menu bar on the left, MEDIA is for the library of mp3’s. http://home.comcast.net/~jeff.wilder/h3puter/media.jpg RADIO is for Sirius satellite radio. Currently there is no AM/FM radio, but I can add it if I ever feel I miss it (I don’t think I will). The FAV button on the bottom cycles through lists of favorite stations. The name of the list is at the top, “Jeff”. SAT: and TER: show the strength of the satellite and terrestrial signals respectively. http://home.comcast.net/~jeff.wilder/h3puter/radio.jpg Road Runner embeds the iGuidance program natively. I’ve used quite a few nav systems, and am pretty happy with iGuidance. It uses NavTeq maps, which I have found to be more accurate in my area, as opposed to TeleAtlas. When navigating a route, I can be in MEDIA or RADIO, and for each turn, it will automatically switch back to NAV, lower the music, speak the direction, and then return to MEDIA or RADIO when I’ve completed the turn. .http://home.comcast.net/~jeff.wilder/h3puter/nav2.jpg TOPO! integration works quite well, also. I had to make some custom AutoIt scripts to pull it off. The “+” and “-“ at the bottom are for zooming in and out. “TRK” will start plotting your position with a red line (example shown). “FIND” will pull up the screen that searches for landmarks. “OSK” is an On-Screen Keyboard for typing in what you want to search for. http://home.comcast.net/~jeff.wilder/h3puter/topo.jpg The backup camera is enabled whenever the truck is put in reverse. The Xenarc display has an AV2 composite input that it will switch to automatically whenever there is a signal on it. So I simply power the camera off the backup light leads. That way the camera powers up and provides a signal whenever I’m in reverse. http://home.comcast.net/~jeff.wilder...r/IMG_3493.JPG Here’s an example of the image in pitch darkness... except for my backup lights and a lampost off in the distance. http://home.comcast.net/~jeff.wilder...r/IMG_3505.JPG __________________ My setup: Hummer H3, iBase MB899, Intel Core Duo, RR, iGv3, DSATX, Mechatroniks chassis, 41Hz AMP3 Last edited by jeffw; 03-06-2008 at 01:28 PM.. |
