Compressor Tire Inflator
Old Jun 11, 2008 | 01:48 AM
Default RE: Compressor Tire Inflator
True....[:@]
Old Jun 12, 2008 | 12:15 PM
pduffy's Avatar
Is the tire inflator only available on certain year models? I have the 2003 H2 and I saw this post and looked in the wheel but I am not seeing anything. Thanks.
Old Jun 12, 2008 | 02:09 PM
solarflare's Avatar
If you open your lift gate, you would have a switch that says inflator on it.....it would be on the lower right hand side...
Old Jun 12, 2008 | 02:48 PM
pduffy's Avatar
I opened the rearhatch and checked but didn't find it. Was it an option or standard? That's strange! [&o]
Old Jun 12, 2008 | 03:04 PM
solarflare's Avatar
it was an option.....you usually have air suspension...if you have the inflator
Old Jun 12, 2008 | 03:10 PM
pduffy's Avatar
That makes sense. Thanks anyway!
Old Jan 5, 2015 | 08:46 AM
pgday's Avatar
Ok, I'm a newbie having just purchased a 2005 H2 with the adventure package. The tire inflator location is missing the cover and I have no idea if I have that option. Is there any way I can confirm whether I have it? If I don't, where can I purchase a cover for the hole or possibly have the option installed aftermarket? Is this a possibility? Sorry for the basic questions.
Old Jan 5, 2015 | 02:38 PM
finall's Avatar
If you have air ride suspension, you have the tire compressor already in your H2.
Crawl underneath, and you will see the bottom of a large metal pan about 1x2' with large holes in it. Thru the holes, you can just see the air compressor. And air bags on your rear suspension.
The hole you speak of should have a bezel with the power switch and air valve located there. at the rear of the RR inside quarter panel, near hatch. The H2 came with about 20' of air hose with pressure gauge, and various inflation attachments in a black vinyl bag. If you do not have air ride, there is either no hole or hole is filled in with block off plate.
fatass88
Dec 1, 2020 07:56 AM
myrddin
Jul 11, 2010 04:30 PM
HEATHERH2
Oct 17, 2006 09:00 PM
hmcoleap
Aug 22, 2006 01:14 PM
shortbus
Nov 3, 2005 08:36 PM
