Clicking near rear end....
Often times when we shut our 2003 H2 off and get out, we will hear a clicking sounds ( 5 - 7 times). I listened underneath when it was happening, and it appears it is coming from the "computer" components located underneath / behind the rear bumper.
Does anyone know what these computer components control , or what the sound may be ?
Thanks in advance
Thanks in advance
Thanks !
We do have a Magnaflow on it, but it is clearly coming from that "computer" box that is covered up under there
The dealer stated they could not duplicate the problem
Of course, when we picked it up, drove it home, it did it
Mike
Mike
I have the same exhaust on mine and no problem. I dont know if the purge valve is located there or not. Normaly that would tag the check engine light. This is just a guess, but maybe the gas cap is not venting right and too much pressure is building up causing the valve to work overtime.
We have a few on this site with some good tech info. Maybe they will chime in.
I suspect it to be normal..Probably the emissions evaporative controls either; 1. pressurizing the system looking for any leaks, or 2. it's the fuel pump shutting down..Course I have an H3 and don't have a clue what it could be....But my Land Rover I had, would do that for about 30 secounds to check the fuel system for integrity.
do you have an air bag suspension or springs? i don't know what computer stuff in the rear you're talking about, but would guess it has something to do with the compressor, assuming you have one.
Hi. found this site by searching for clicking noise.
I too have this noise on my 04/H2. It just started. It only happens after it has been driven abd only lasts for seconds after you park.
sounds like a solinoid clicking. Took it to the dealership "didnt make noise" service guy said it could be the air ride pump? but wasnt sure.
My noise has stopped in the last few days as I have the back loaded with some parts. I wounder if this added weight has anything to do with the noise stopping?
Would appriciate any more opinions
Mark
Mark
