Check engine light on after upgrades
The check engine light is on now after I had a K&N air filter sytem and catback exhaust installed. On star diagnostics says the engine is running too lean and is sputtering. Is there anything that I need to have done now to correct his or should I replace everything I had taken off? Thanks
RE: Check engine light on after upgrades
Keep driving, it may take 100 - 200 miles for your PCM to learn to learn to compensate by increasing fuel mixture etc...
Make sure the MAF Sensor is properly connected and snapped tight at the plug. |
Also with the K&N filters, some are over charged. (too much oil on the filter). This can cause issues as well.
| All times are GMT -5. The time now is 06:15 AM. |
