can someone tell me location 06 h3 knock sensor
can someone tell or share pic where located? moms truck and dont live with so trying to make sure can do at her house and bring what i need. there is only one? correct?thanks
I believe if I am remembering correctly it is in just in front of the starter on both the i5 and v8. You can probably google it and find an engine diagram.
thanks, found it listed as left side of engine between cyl 3/4 access through wheelwell. was sacared a minute as i seen h2 has two and located under intake manifold.
you're welcome. Yes, don't mix it up with the h2. Let us know if it takes care of the problem too. Thanks
