Can I do 22
I want to add XD rock star rims to my truck and the 20s look small Can I do 22 stores keep telling me that 20s where as high as I could go without a lift is that true? I think I have read a few times that you can do 22 with no problem thats what I want. I want them to be wating for me when I get back from afghanistan I have less than a month and a half before I get home.
Recommend you use the search to answer most of your questions but here is a link to a good website that will set you up right.
Tire Rack - Your performance experts for tires and wheels |
when you do them sights it tells you 20s are max I want 22 and I have seen 22s on alot of hummers I dont think they all got lifts so I am wanting to know it might not be recomended but yes you can or no you cant.
Yes but you need to use the site so it will teach what dimensions youll need to match up your tire size so you wont need a lift.
You can do it without any lifts, there is no problem.
Thanks thats what I thought but did not want to drop $3000 on rims without knowing.
Also does any one have suggestions on the best places to go. |
Id stick with 20's. 22's look to weenie IMO and makes it look like it might as well be two wheel drive.
I have seen alot of H2 with 22" on them and think they look pretty good. But I also want to be able to go off road when you guys put together a Off road rally.
all of my hummer limos run 22s.No problems at all and most of my hummers weigh in at over 14k pounds.
Im running 325/50/22 nitto terra grapplers and im getting 10k miles on each set before i see serious wear.And our limos arent Lifted at all.Just make sure you go with a good wheel and check the load rating some of the cheaper wheels are lower rated and can crack.Also i run my psi at 55 and i havent had a bent or cracked rim in over a year. I am running davinci wheels on all of them and have been pleased with the look. |
Should I be worried If I towe my boat its weights about 8000 pounds if not more fully loaded. I could get high impact tires like I had on my avalanch will that help.
