-   -   Broken bolts on manifold for catalytic converter (https://www.hummerforums.com/forum/private-sale-trade-classifieds-10/broken-bolts-manifold-catalytic-converter-36878/)
Carbon24K May 18, 2016 03:21 PM
The dealer told me I needed a new catalytic converter. Now at installation he tells me two bolts are broken requiring the removal of the manifold.
I was told it is a 12 hour job at a cost of $1900 bucks. That does not include the install of the new catalytic converter at an additional $1800. total $3700
I need a little help . . . are they off the wall or is this pretty close to the right cost.
Thank you
Happy Hummer May 18, 2016 07:24 PM
Haha... run do not walk.
The cat/manifold can be gotten for between 350 & 700 approximately the bolts can be extracted by a competent shop with proper tools. At say 85 per hour for a few hours to remove the broken studs and the installation of a manifold cat you should be in the 2k range or less.
Bunger May 19, 2016 01:16 AM
A dealer is the LAST place I would take my vehicle.
Go to a good independent mechanic for a reasonable cost.
Doc Olds May 19, 2016 09:58 AM
Thank you
What two bolts? Are we talking about bolts at the collector of the exhaust manifold/Cat pipe flange, or bolts to the head for the exhaust manifold? Any monkey can fix broken bolts at the collector without removing the manifold???? They use this thing called a drill.
Did they break the bolts while attempting the replacement???
There are two Cats for an I5 H3, one mini in the Exhaust Manifold, and a full Cat in the mid pipe behind the manifold. If they are replacing the rear Cat, no reason to mess with the Manifold.
