Brake Lines for the Hummer H2
We have our Hummer H2 complete brake line kits on sale.
Here is the complete kit in steel for $170. Here is the complete kit in stainless steel for $249.95. If you use code Hummer at checkout, we will give you an additional 10% off your entire order. Either kit also qualifies for free shipping already. Our website if you are looking for anything else is www.sstubes.com |
Stainless price is a bit high.
I have adjusted our pricing on the stainless kit. It is now $190 retail, plus you still save an additional 10% with code Hummer at checkout.
i have a set of your SS brake lines and braided hoses. they have been holding up extreamly well. only issue i had was it did not clip back onto the the existing line holders as your lines are a bit beefier then stock but that's not a bad thing i guess.
Interesting, I'm thinking about buying a set just to keep around. Bronxteck, any other issues you had with the install or anything?
nope no issues that I can recall other than SS is a few mils beefier and a bit hard to bend if needed they fit reasonably well for a great aftermarket option. I'm sure if the plastic line holders on my truck where 17 years younger maybe I could jam them in but being that old the plastics are hard and rigid. would be nice if the kit came with new line holders.
Just a bit of heat from a heat gun on the clips makes them flexible. Secure lines to the holders with zip ties also works. Just make sure to secure the lines, so they aren't bouncing around rubbing on the frame, causing premature failure!
| All times are GMT -5. The time now is 04:43 AM. |
