Bilstein 4600 Series
Old Sep 18, 2013 | 09:06 PM
H2Miami's Avatar
New shocks installed ... Install was easy , just 2 bolts X each one .. BTW you will need a deep 21 socket to remove the bolts on the back .
Installing the fronts I notice one spill a little of gas when I pushed and release . it happens twice ... Is that normal or should I replace that one ...
I havent drive it with the new shocks yet , I will do the test tomorrow ,
The OEM were all bad , in fact one spill fluid when removed ... I wasn't expecting to replace the shocks in a heavy duty offroad truck with only 75,000 miles .... Not good
Old Sep 19, 2013 | 12:27 PM
H2CANEPADESIGN's Avatar
I do a lot of shocks and struts at my shop here. You would be surprised how soon some of that oem stuff goes bad. most vehicles with Monroe's need replacement before 30,000 miles.
Old Sep 19, 2013 | 10:40 PM
H2Miami's Avatar
Do you know if the gas spill from one of the shocks is normal ( explained in previous post) ...
Old Sep 21, 2013 | 11:10 AM
If there is moisture spilling from the shock then the seal is bad. If its a bilstein they will warranty it. there should be no/very little moisture around the shaft of the shock. sometimes you will get a very very minimal amount of oil around the shaft when they age, that is normal but anything more than a very light coating of oil is a blown shock.
Old Sep 25, 2013 | 12:10 AM
H2Miami's Avatar
Thanks H2cane .. I dont see any fluid around , it was just a gas what spill . I will check again for any marks .
BTW I it wos totally worth it . much better ride plus a couple annoying noises disappear .. In fact I havent felt the bumping noise I talked before . Will tell for sure after this friday towing 3000pnd for 300 miles .
Old Sep 27, 2013 | 11:43 AM
Congrats and welcome to the bilstein family . I swear by em and always have.
Old Oct 1, 2013 | 10:29 PM
H2Miami's Avatar
H2cane .. Do you remember the bumping noise i talked before , I was planning to replace the hubs but after installing the new shocks the noise disappear . can believe it . was bothering me for a while
I Just took a 300+ miles trip and it was fine , I hope it stay like that . It was making me crazy
Old Oct 2, 2013 | 11:40 AM
There are soo many things that can cause that kind of noise. it even could have been the rubber bushing in the bottom of the old shock mount that was rotted causing the shock to move a little in the mount.
Panzerh2
65
Nov 4, 2016 12:15 PM
Gunner_45
Jul 14, 2011 01:45 PM
hotrodthom
Oct 28, 2008 01:44 PM
solarflare
Apr 24, 2008 03:32 PM
hotrodthom
Sep 3, 2007 07:05 PM
