Bigger Rims = Lower MPG?
Old Mar 12, 2010 | 08:04 PM
Franky3030's Avatar
Default Bigger Rims = Lower MPG?
I ve googled this question a million times and it's like Einstein is needed on this one, some people say bigger wheels help some say they make it worse so I would like to hear the answer from somebody who has already experienced this with their H3. I currently have 20' s with 275/60/20 tires on my H3 and im thinking about getting 24's or even 26's if possible, i ve seen how crazy h3 s look with 26's but I would like to know the consequences before buying. can you help?
Old Mar 13, 2010 | 06:47 AM
trip4219's Avatar
unless you're getting some titanium rims that size you're going to be adding a lot of weight...more weight equals less mpg...
Old Mar 14, 2010 | 08:31 AM
D VADER's Avatar
As the wheel gets bigger the mass of the weight moves farther out. This requires more horsepower to turn that wheel. It also require more braking force. The H3X offered 18" rims but going over 20" can present some problems. I know from experience it can impact your warranty.
Bob
Old Mar 17, 2010 | 08:55 AM
supsam86's Avatar
If you are looking for more info on what Dublatime is saying here is one of my old posts about 35 inch tires, the same principle applies to large wheels and tires with an overall diameter of 35 inches:
"I recently put 315's (35's) on my H3 with the 3.7l and leveled it out to 23 inches. I've seen some of you asking about how that might affect the mileage or driving quality. I can say that the driving quality isn't noticeably different from stock, so long as you get your camber angles readjusted at the alignment shop. You might notice that the wider tires will grab the grooves in the road a bit, but that's the way it is with any wider tires.
As for gas mileage differences, there appears to be a big difference AT FIRST. When i first swapped out the tires, I was averaging 12.6 mpg. BUT that is before it occurred to me today that my trip odometer information was inaccurate because the new tires cover more distance than the old ones.
I'll explain: My '07 H3 came with 265/75R16 tires which are 31.6 inches tall and have a circumference off 99.4 inches. The new 315/75R16 tires are 34.6 inches tall and have a circumference of 108.7 inches. This means that for every one full rotation of the tire I am covering 9.3 inches more than the stock tire.
The factory speedometer and odometer were calibrated to the specifications of the factory tires. As most of you know the bigger tires mean that you have to have your speedo recalibrated, but what I have never seen discussed is how this will offset your MPG calculation. So I did some math...
One mile = 5280 ft.
A 31.6 inch tire (99.4" cir) will rotate 637 times per mile
A 34.6 inch tire (108.7" cir) will rotate 583 times per mile
If the speedometer reads 55mph, with 35's I am actually doing 60 mph (conveniently exactly 5mph difference all the time).
This means that if the odometer says I've driven 91.47 miles, I've actually driven 100 miles. This equates to a 9.33% differential from what the odometer reads.
To put it in plain English: if I go to the gas station to fill up and I want to figure MPG, this is what I do to get it right:
Trip odometer reads: 250 miles
250 X 0.09333 = 23.3325 (real extra miles to be added)
250 + 23.3325 = 273.3325 (actual distance traveled)
273.33 / Gallons used = correct MPG.
*this also means that if I never get the speedo or odometer recalibrated then I will end up slightly retaining resale value: I can drive 109,333 miles and the odometer will only show 100k "
stabwound17
18
Apr 22, 2011 08:31 AM
supsam86
Feb 10, 2010 07:21 PM
Niznac
Dec 21, 2008 12:53 PM
backroads33
Nov 1, 2006 12:32 AM
hummerific
Feb 5, 2006 05:59 PM
