Big 3 upgrade
Has anybody done this upgrade to the wiring on their truck to help compensate for the dimming lights that are caused by having a sound system in your truck?
I found a pretty good write up about it here: http://forum.sounddomain.com/ubbthre.../312025/page/1 I was wondering if anybody on these forums has done it. |
i think the only bass notes that would ever dim lites would be from that "thump-thump" that some morons play with. its not music
if u need it ,heavy wires always help. id use a 2nd batt if i were a moron and played thump-thump in all cases crimping without soldering is setting up a future problem with corrosion, creating higher resistance nobody will ever play real music at dimming levels for a long enuf time to matter anyway,,its only done to impress people, by people desperate for attention. ifn u due pla it longer,,ure ears will slowly die and u wont matter jus my opinion ps, i do liks smashing real music in my monsoooons |
just buy a capacitor, they'll store enough power for the max wattage hits
I have played " real music" and got my lights dim it just has to do with your settings, hell I played new York new York by frank sinatra pretty loud and my subs were able to drain enough to turn lights down, Wiring won't really help the car drain you would need a second battery or capacitor if your running bigger subs. Now if you put higher end tweeters and door speakers that need their own amp then your looking at new wiring for whole system.
capacitors
a one farad cap will run a 100 watt amp for,,,1 second!,,a batt is like 1000's of farads
Originally Posted by drtom
(Post 235975)
if u need it ,heavy wires always help. id use a 2nd batt if i were a moron and played thump-thump in all cases crimping without soldering is setting up a future problem with corrosion, creating higher resistance nobody will ever play real music at dimming levels for a long enuf time to matter anyway,,its only done to impress people, by people desperate for attention. ifn u due pla it longer,,ure ears will slowly die and u wont matter jus my opinion ps, i do liks smashing real music in my monsoooons I'm assuming you must text allot ? |
(Post 235989)
im not debating anything,just stating facts to help decisions
allot ? |
You're a moron
(Post 235975)
Originally Posted by BlackMamba08
(Post 350779)
you probably think the stock system is loud as ****. You're the kind of guy to go to Wal-Mart for subs
See: https://www.hummerforums.com/forum/n...bumping-23220/ |
| All times are GMT -5. The time now is 01:33 AM. |
