BFG A/T 305/70R16 on stock rims rubbing...
I have a2007 H3 Base model with a front leveling kit even front to back. I had BFGoodrich All-Terrain T/A KO 305/70R16 installed on my stock rims.The inside front of the tires rubon the tubular metal bar when I turn the wheel all the way right or left. It has left an obvious black mark.
I want to keep my new tires mountedon my stock rims. Would wheel spacers resolve this issue? If so what is the minimum size and where do I purchase such an item? http://pic20.picturetrail.com/VOL89/.../296070613.jpg |
RE: BFG A/T 305/70R16 on stock rims rubbing...
That's the swaybar. ;)
Stock tires will even rub the swaybar sometimes when turned at full lock. I wouldn't worry about it. |
not too big of a deal,just remeber when at full lock,ease up a lil,it will still turn on a dime.
ORIGINAL: hilljob26 not too big of a deal,just remeber when at full lock,ease up a lil,it will still turn on a dime. |
Hey, the truck looks good. You may have helped me with my next tire purchase, though I'm not putting on the leveling kit unless necessary to fit the tires. [/align]
you can go with a small spacer with no problems.....bigger rigs than the h3 have been running them for years. If you get a spacer plate just make sure you have enough lug threads left to get through the lug nut. If you go with a one inch or more spacer get the kind that the spacer mounts to the hub using the original lug nuts ...bolts on like a rim...then the spacer itself has it's own set of lug bolts..I'm using a set of these from spyder in the Jeep.
Thats a good looking setup, but can you add some more pics from the front or rear and how about a full on side shot? Just getting our H3 tonight and been trying to decide tire size & brand, etc.
Thanks |
Looking good Nova, I have the same tire but the 285 /75/16really happy with the tire. Are the 305's 34 inch?
Thanks to everyone for the quick replies and information.
I definitely want to stop the rubbing it annoys me and scares the crap out of any passengers. I constantly hear " [sm=WTFsgign.gif]was that?" By the end of the day I find myself checking the tires to see if the inner lugs have torn off. SteveO - Thanks. I believe that the 305/70R16 are 33" tall and 12.2" wide tnd2 - Here you go... http://pic20.picturetrail.com/VOL89/.../296169221.jpg http://pic20.picturetrail.com/VOL89/.../296169224.jpg http://pic20.picturetrail.com/VOL89/.../296169227.jpg http://pic20.picturetrail.com/VOL89/.../296177768.jpg importkiller - Excellent information. Any advice on the best place to look for price and quality? alrock - Glad I could help. LesC. - Thanks for pointing out the white letters. Now I'm going to have to black them out. [:@] hilljob26 - Thanks for thecomment on the turning radius. I was wondering about that. Sewie - Thanks for naming the tubular metal thing for me. :eek: I almost didn't post thisfor lack of knowing what it was calledand decided a picturewould be better than any description I could think of. Nova... [sm=crossbonesgif.gif] |
Your 285/75r16 should be 32.8x11.2, and the 305/70r16 should be 32.8x12.0 mathematically(had to use spell check for that one) anyway. The real size could be diffrent and only determined by a tape
