-   -   Battery Light on? (https://www.hummerforums.com/forum/private-sale-trade-classifieds-10/battery-light-3144/)
Rich Sims Jan 8, 2007 07:38 AM
Battery Light on?
Hi All just recieved a black H2 to play with but the battery keeps going flat :(when you turn the ignition off the battery light comes on and I cant turn the dash lights off!
Can anybody help, thanks in advance..
HummBob Jan 9, 2007 06:21 AM
RE: Battery Light on?
I think the battery is TOAST!!!
GM uses CRAP batteries.
I received 2 new batteries through warranty cause they kept dying before I finally GAVE UP and bought an Optima Yellow Top!! No Probs since!
Sugardaddy Jan 13, 2007 02:17 PM
My battery went dead twice within the month or so that I had it.
sterlingmarlin30 Oct 19, 2009 05:23 PM
my h2 is doing exactly the same thing, also sometimes the radio stays on as well, I have to dim the dash lights to keep the battery alive overnight, if you find a cure please share
calif phil Oct 20, 2009 08:44 AM
If the battery stays on when you shut the truck off you WILL have a dead battery in the morning. The most common cause is an igntion switch going bad. They are under $40 and not too hard to replace.
sterlingmarlin30 Oct 20, 2009 06:17 PM
this is the actual key switch you are talking about? got 1 on order
BIGT2148 Oct 20, 2009 08:21 PM
The lights on and electronics acting weird is a key indicator that the battery is going dead. I have a GM battery currently since HUMMER gave me a new one.
I am going to go aftermarket and I would suggest that. Also get that ignition checked.
Something to think about....when my H2 is not being driven, I have it hooked up to a battery tender. It keeps her fresh! =)
calif phil Oct 21, 2009 08:34 AM
There are two parts to the igntion switch, the lock cylinder and key and the electrical switch behind the lock cylinder, You need the electrical switch.
lionel90 Jan 13, 2014 04:04 PM
Hello,
Because I have the same issue (battery and dash light on when I turn the ignition off), do you remember your solution ?
Only change the battery or anything else ?...
Thanks in advance.
