Battery Light on?
Old Jan 8, 2007 | 07:38 AM
Rich Sims's Avatar
Default Battery Light on?
Hi All just recieved a black H2 to play with but the battery keeps going flat when you turn the ignition off the battery light comes on and I cant turn the dash lights off!
Can anybody help, thanks in advance..
Old Jan 9, 2007 | 06:21 AM
Default RE: Battery Light on?
I think the battery is TOAST!!!
GM uses CRAP batteries.
I received 2 new batteries through warranty cause they kept dying before I finally GAVE UP and bought an Optima Yellow Top!! No Probs since!
Old Jan 13, 2007 | 02:17 PM
Sugardaddy's Avatar
My battery went dead twice within the month or so that I had it.
Old Oct 19, 2009 | 05:23 PM
sterlingmarlin30's Avatar
my h2 is doing exactly the same thing, also sometimes the radio stays on as well, I have to dim the dash lights to keep the battery alive overnight, if you find a cure please share
Old Oct 20, 2009 | 08:44 AM
calif phil's Avatar
If the battery stays on when you shut the truck off you WILL have a dead battery in the morning. The most common cause is an igntion switch going bad. They are under $40 and not too hard to replace.
Old Oct 20, 2009 | 06:17 PM
this is the actual key switch you are talking about? got 1 on order
Old Oct 20, 2009 | 08:21 PM
BIGT2148's Avatar
The lights on and electronics acting weird is a key indicator that the battery is going dead. I have a GM battery currently since HUMMER gave me a new one.
I am going to go aftermarket and I would suggest that. Also get that ignition checked.
Something to think about....when my H2 is not being driven, I have it hooked up to a battery tender. It keeps her fresh! =)
Old Oct 21, 2009 | 08:34 AM
calif phil's Avatar
There are two parts to the igntion switch, the lock cylinder and key and the electrical switch behind the lock cylinder, You need the electrical switch.
Old Jan 13, 2014 | 04:04 PM
lionel90's Avatar
Hello,
Because I have the same issue (battery and dash light on when I turn the ignition off), do you remember your solution ?
Only change the battery or anything else ?...
Thanks in advance.
gregaac
Aug 17, 2021 03:20 PM
magicchiz
Aug 13, 2013 05:58 PM
H2Promotions
Nov 26, 2012 05:39 AM
Champ53
Jul 19, 2011 02:26 PM
sterlingmarlin30
Oct 18, 2009 07:06 PM
