ARB Air Locker
Has anyone installed the ARB front air locker on their H3? I'm thinking of ordering one and wanted to know if anyone has first hand knowledge of it's pro's and con's?
Thanks! HMH3 |
Absolutely a LOT of people have installed them. People have also installed the factory Adventure lockers as well.
If I install the Adventure lockers will they integrate electronically with the factory system I already have, or will it be a wiring nightmare? Just looking for the best way to get front lockers. I found the air lockers online, where do you get the Adventure lockers?
Thanks! |
I "believe" all you'd have to do is run the toggle switches up to the cab and prolly a power line. You can find adventure lockers in the for-sale sections and online at different vendors. Did you get my message?
Originally Posted by 85_305
(Post 229085)
I have wheeled with alot of people that have them and none have had any problems and the ARB compressor is pretty quiet. I am about to order on from *********************** they are running a really good sale right now. They have it cheaper then I have seen them yet.
Originally Posted by talusfan
(Post 229104)
Interesting, considering Arb is an air locker and not electronic, You also need to install a compressor for said AIR locker to work, and the associated wiring.
Thanks guys!
I will look for the 'Adventure Lockers' and see what I come up with. Would really like to have the cast iron differental. The ARB lockers are $845, plus the compressor (the HO one to air up the tires too), switch plate, switches, airline, all installed $1800 out the door. Either way I'm gonna get lockers by the end of the month!:D |
The advent. lockers are cast iron :tu:
I have front and rear arb lockers with a 9l tank to run it and the air horn as well as the air bags for the rear springs it is great
| All times are GMT -5. The time now is 07:11 AM. |
