Anyone change the brakes on the 2006 h3 yet....
I am getting alot of squeeks from the front brakes now so I was curious if anyone has changed it and about how long it took? Any special tools required for the hummer h3? Anyone take pics?
RE: Anyone change the brakes on the 2006 h3 yet....
I changed mine about 6 months ago, about 35K miles. I wasn't squealing yet but was really getting done there, so I changed themso I didn't have to touch myrotors. Itonly took me 20 minutes a side to do, I ended up buying a couple of cans of brake cleaner and cleaning up everything and painting my brake calipers at the same time, came out mine!
Good Luck! [sm=gears.gif] |
Any special tools required or no?
I had 35k on my '06 and they were squeaking a little at the very end of every stop. I took the wheel off the front one and there was at least 50% pad left. So I took it in to the dealership and they replaced all 4 for free, saying the new 08's have "upgraded" pads and they've been getting a lot of issues with the '06's. Not really sure what the issue was though..
Just thought I'd mention that.. |
No special tools needed, if I remember right I used a 18mm socket, screwdriver, hammer, a hex head (can't remember what size). If you have all the basic tools in aset, your all set. The only thing I went to buy was a cheap large C clamp to close back up the piston on the caliper and that was about $8.00 at Ace True Value.
i would search and see the other threads
this was the easiest brake job i have ever done, you do not even take the calipers off |
Well I will be doing it this week so I will post pics of the process for everyone.
Hey guys new to the form i'm having the same front break issue but not all the time[8D]
ORIGINAL: thehammerh3 I am getting alot of squeeks from the front brakes now so I was curious if anyone has changed it and about how long it took? Any special tools required for the hummer h3? Anyone take pics? |
I have 42XXX miles on mine and rotated my tires last week. I checked the pads at they have plenty of material left, but I did notice that the front rotors are pretty grooved. I have noticed a drop in braking power, but that may be due to me not bleeding the brakes in the 3+ years I've owned the H3. Has anyone done a full brake fluid replacement themselves or did you take it to the dealer? Thanks,
Mike |
