Anybody have 325/65r18 (35x12.50) tires on their H3?
Old Feb 12, 2013 | 08:20 PM
skeeter's Avatar
I believe mine are -12mm, but I know that the backspacing is 4.5" and it is the number i would be most concerned with
Old Feb 12, 2013 | 08:22 PM
skeeter's Avatar
Originally Posted by Andreas_Sweden
Like the look of your H3
Thanks. I have been getting alot of compliments lately
Old Feb 13, 2013 | 06:57 AM
amrg's Avatar
If you had a 315 wide tire would that end up rubbing on the mud flaps with your setup with -12 offset? I want to order a set of wheels and dont want to remove the mud flaps.
Btw I like what you did to your fenders. Its a great way to hide all the carnage the fenders get from all the debris flying off the front tires
Old Feb 13, 2013 | 07:00 AM
amrg's Avatar
The H3 with the new rubber
The Fierce MT were delayed and I didn't have time to wait so I went with the 35" mud grapplers instead.
Whats the offset of your wheels? Can you please post more pics?
Old Feb 13, 2013 | 07:57 AM
Andreas_Sweden's Avatar
Saw that I wrote mud grapplers, actually it is the trail grapplers.
Don't know the offset got them through SD wheelcorp and just told them it is for a H3
Attached Thumbnails Anybody have 325/65r18 (35x12.50) tires on their H3?-img_1344.jpg   Anybody have 325/65r18 (35x12.50) tires on their H3?-img_1346.jpg
Old Feb 13, 2013 | 04:04 PM
Bunger's Avatar
Guys,
DO NOT get fixated on Offset numbers. Offset will be different on different width wheels.
The important dimension is BACKSPACE.
Backspace on OEM H3 wheels is 5.75".
You want to stay close to that number to insure clearance for the wheel and steering components, brake calipers, etc.
A larger backspace will cause inner wheel clearance issues.
A smaller backspace will make the tires extend out more and may cause tire rubbing in the wheel wells, mud flaps, etc.
Old Feb 14, 2013 | 05:00 AM
amrg's Avatar
Backspacing is needed for the caliper clearance, smaller backspacing = more clearance.
Wouldn't offset though allow us to know how much more the (Tire) would stick out/in? Since its a measurement from the wheels center line, its independent from wheel width.
Old Feb 14, 2013 | 05:45 AM
Bunger's Avatar
Backspace = The distance from back of the wheel to the wheel's mounting face, in inches.
You NEED a certain backspace for our trucks.
OEM wheel is 7-1/2" wide
Aftermarket might be 8", 9", etc.
OFFSET is a result of wheel width & Backspace.
You can't buy aftermarket rims based on Offset alone.
Old Feb 16, 2013 | 07:40 PM
vroomazoom's Avatar
Just got my 35 x 12.5 x 20 Nitto Trail Grapplers mounted on 20 x 9.5 Lexani RBP wheels
The wheels have a 5.5 offset, torsions cranked up to 23.5 inches and alignment done. Tires rub sway bar at full turns right or left, really minor.
Otto7668
Nov 9, 2012 05:39 AM
vlorito
Dec 6, 2008 08:50 AM
j.5
Oct 16, 2008 03:10 PM
coreyc
Jan 14, 2008 10:00 PM
importkiller
May 22, 2006 11:32 AM
