Any One Have a Light?
Marker light that is!..Does anyone have or know where I can find a top,rear corner,passenger side, red marker light assembly for an 06' H2 SUT? The clip on mine is broken and the only thing holding it on is the screw..and not very well!
Thanks!
Thanks!
This will be the highest price you will find! Might be cheaper to go to the dealer and work on the parts counter guy. They have some leeway on price.
If you want to order it thru the internet. Check around on a few different GM Parts sites. Make sure to check the shipping before ordering!
GM Parts | GM Accessories | GM Parts House
GM Parts Cheap - OEM Genuine at Wholesale
GM Parts - Genuine Replacement GM Parts - New GM Parts
Not trying to be smart...just unscrew the screw! Mine were just attached with one simple screw..thats it! Then the entire lens lifts off to expose the lightbulb and socket. Be careful you don't mess up the backing on the bottom of the lens assembly, you may cause a leak if not seated properly when you put it back on!
Sorry, those require a little more finess! Mine have the word GUIDE 8N3 on one end...on that end there is a metal spring clip underneath. You have to carefully pry under the light and depress that clip to get it lose. Same applies to the gasket and the seating when you replace them tho!
theviper90210
Dec 28, 2010 08:54 PM
FloridaFeMan
Feb 8, 2010 10:51 AM
H3CHICKY
Aug 6, 2007 08:01 PM
