Alpha question
Old Jan 30, 2013 | 07:40 PM
nijoma's Avatar
Default Alpha question
How many belts are on the front of the engine? 2 ? Got a hell of a squeak/tick, sprayed some WD40 on the belts and sound went away for a bit. How many miles should these belts last? Plan on replacing them.
Old Jan 30, 2013 | 07:50 PM
RKSmith163's Avatar
2 belts. The serpentine belt runs everything but the AC compressor. Check the maintenance schedule in your owners manual for inspection and replacement.
Old Jan 31, 2013 | 01:40 PM
Changing of the belt(s) is NOT based upon mileage, there is NO set interval, but it will typically be between 60-100K miles. Spraying solvent of a belt is never a good idea?
You change a belt based upon inspection. Your squealing can be caused by an tensioner pulley spring getting worn out and potentially have nothing to do with belt condition. Some will tell you when it is time to replace the belt, replace the tensioner or vice versa.
If you have cracks (many), glazing, fraying, or loss of belt material. If any of that is going on, replace.
Old Jan 31, 2013 | 07:22 PM
nijoma's Avatar
Default Thanks
Serpentine belt was going, 52k miles. Swapped it out today.
Old Feb 3, 2013 | 09:04 AM
mvrocky's Avatar
I changed mine at 30k last month(it was cracked and slipping), belts go bad with age, mileage,enviroment and grade of belt. it's not just one thing.I live in the Northeast (high salt area).
ShirtaDay.com
May 18, 2010 03:38 PM
Prym
Mar 18, 2010 01:26 PM
H3 Xman
35
Jan 31, 2008 10:04 AM
nocturnaltrader
32
Dec 18, 2007 09:34 PM
EJPhoto
Oct 20, 2007 09:26 AM
