Alignment
Old Sep 29, 2007 | 07:51 PM
bsmitty's Avatar
Default Alignment
I recently bought an H3 (2007) usedand have had it for about a month. I have noticed a faint knocking/rattling noise from the front left side when I hit a bump. Today I took it off road for the first time and the noise was more noticeable. After the off roading adventure, my steering wheel is off center, but I don't feel any pull to one side or the other (needs an alignment?). To add to this confusion, I didn't notice the noise on the ride home. What could this be? Also is it normal to need an alignment after tough off road driving?
This is my first post here and I'm new to off roading so take it easy on me :-)
Old Sep 29, 2007 | 09:19 PM
bsmitty's Avatar
Default RE: Alignment
Just searched the forum archives and found that others also report the same noise.
https://www.hummerforums.com/m_67824/tm.htm
So, I guess I need to have a chat with the dealer about the stearing shaft.
Could this have anything to do with my steering alignment now after my off road adventure? Or are the two unrelated?
Old Sep 29, 2007 | 09:43 PM
I do not know what you did specifically off roading, but no, you should not knock your alignment out just because you went off road. The steering shaft problem, assuming you have it, is not related to any alignment adjustment, at least not that I have heard of yet? So I'm guessing unrelated. Welcome to the forums just the same.
Old Oct 1, 2007 | 05:29 AM
hilljob26's Avatar
welcome,although off roading shouldnt take your alignment out,you can tweak it out depending on how hard you wheel.its just like hitting pot holes in the street,every little thing will add up
Old Oct 1, 2007 | 01:23 PM
Muddydawg75's Avatar
It's always possible you bent a Tie rod.... or as simple as your tire is low.... every now and then when I wheel I will come out with a tire that is 5-10 psi low.... it holds air fine... it isn'ta slowleak...but it pulls hard until I get it aired up again..
Old Oct 1, 2007 | 05:08 PM
bsmitty's Avatar
Took it to the dealer today to have the steering shaft replaced and they told me I bent a tie rod. Muddydawg got it right!
$525 for parts and labor (includes the alignment). Probably getting screwed because it's the dealer...
Old Oct 2, 2007 | 05:09 AM
hilljob26's Avatar
ORIGINAL: bsmitty
thats exactly why i do things for people for 1/2,i mean 500 bucks for a tierod,i can get an alignment for 40 bucks,that rediculous
solarflare
Feb 8, 2008 08:17 PM
jm4490
16
Apr 10, 2007 12:25 AM
Fever4Speed
Feb 21, 2007 12:17 AM
WOLFGANGSTA
28
Jan 26, 2007 06:44 PM
07_H3
Jan 10, 2007 04:27 PM
