-   -   Airbag light came on.... (https://www.hummerforums.com/forum/private-sale-trade-classifieds-10/airbag-light-came-9230/)
thehammerh3 Jan 8, 2008 03:29 PM
Well out of know where the dam airbag light came on and wont go off. I hope this thing doesnt explode in my face ha.
2L8IWON Sep 20, 2008 02:24 PM
RE: Airbag light came on....
Did you ever get any resolution on this? Mine just did the same thing as well.
- Jesse
TINKED Sep 27, 2008 06:41 PM
Mine did the same thing and I took it in. they said it could go off at any time. You can see other posts on this.
All under warranty. Good Luck, nothing to screw around with.
HawaiianH3 Jan 2, 2012 11:27 PM
What if your vehicle is no longer under factory warranty? I would like to think that this being a severe safety issue that GM would cover the cost?
Unreal, the wife's just came on while driving home tonight. 06 3.5 Base.
sandkiwi Jan 3, 2012 02:54 AM
Check the fuse......maybe it has blown, if so replace the fuse, if not blowen, make sure there is no dust/dirt/sand etc in there and that the fuse ends are clean so can make good contact......then if no success get it checked.....
I take my fuse out every weekend for dessert driving and put back in afterwards..done this for 2.5 yrs no problem...recently light came on when fuse was in after taking in/out a few times light went off and the correct orange light came on to show working...good luck...:)
23111H3 Jan 3, 2012 10:37 AM
Mine came on for the passenger side. Turns out it was the seat sensor. I reached
underneath the seat and the cluster plug had come slightly loose. I gave
it a squeeze, light went off.
asutrave Mar 13, 2017 12:12 PM
Bump 3/13/2017
Hey guys, was just wondering on any other diagnosis on this issue. My airbag light has been on for a long time, and I cannot figure out what to do to make it go away. It is for the passenger airbag. I have removed/checked/put back in all plausible fuses. I tried to check under the seat for any loose harness, but either I cannot find it and I am not unsure what to look for. I drive my friends around often so it would be comforting to me to know that they are safe.
TAINTER Mar 14, 2017 05:22 AM
You may need to replace the pressure switch in the passenger seat.
Dionkraft Mar 14, 2017 11:17 AM
You need to extract the airbag error codes and go from there.
WR3NCHE4D Mar 18, 2017 09:48 PM
Codes numbers and descriptions always help. I had a passengerpresence code in mine a while ago. Most of the systems run a low amp, low voltage system and even little tarnish can throw a code. Unplugging the module and plugging it back in was all it took to get the light out. It's been out for a year now. My code was B0092 - Passenger Presence System 1 circuit failure. May not work for your air bag problem.
