-   -   Air-Compressor (https://www.hummerforums.com/forum/private-sale-trade-classifieds-10/air-compressor-11198/)
HARDxCOR3 Apr 3, 2008 10:33 PM
Air-Compressor
Stopped into Harbor Freight today in Saddle Brook, NJ and picked up a 12vdc air-compressor on sale for 49.99 here's the link
http://www.harborfreight.com/cpi/cta...emnumber=93186
Trey124 Apr 4, 2008 08:31 AM
RE: Air-Compressor
Not too bad, 3 mins. to air up a tire.I went with the PowerTank which is more expensive, but you can run some air tools in case you breakdown on the trail.
dwaxman1 Apr 4, 2008 08:39 AM
RE: Air-Compressor
Did you mount this inside, in the back?
shortbus Apr 4, 2008 09:11 AM
RE: Air-Compressor
it will fill a CAR tire in 3 minutes - plan on a bit more time to reinflate the tires on the H2. looks like a good deal though. all it needs is a quick connect power plug so you don't have to open the hood to connect it to the battery.
dwaxman1 Apr 4, 2008 09:27 AM
RE: Air-Compressor
you can't mount it for good inside the back? Wasn't there an option to have one inside from factory?
shortbus Apr 4, 2008 11:12 AM
RE: Air-Compressor
the factory mounted compressor mounts under the chassis, behind the rear differential. there is no inside compressor mounting location, at least not on the early models.
dwaxman1 Apr 4, 2008 09:31 PM
RE: Air-Compressor
hoq is the factory one, any good??
tonym4 Jun 18, 2016 06:11 AM
Looking to replace my OEM compressor for a better one to use power tools. Any tips?
honda400ex2003 Jul 6, 2016 03:40 PM
any number of compressors would probably work, size is the main concern for getting it in the back. you might even be able to find a direct replacement compressor that is aftermarket if you have an OEM number to reference to.
steve
