Advice on Tire Size for 18" stock wheels
Old Oct 22, 2009 | 12:58 PM
northm's Avatar
Default Advice on Tire Size for 18" stock wheels
Hi folks,
I own a 2007 H3X with 18" stock wheels. I believe they are 7.5" wide. It's time to get new tires and I would like to beef it up a bit. What is the largest tire size that these wheels will accomodate? I'm not looking for mud, just larger AT tires. I'm leaning towards BF Goodrich AT/KO. Thanks for the assistance!
Old Oct 24, 2009 | 05:52 PM
northm's Avatar
Can anyone help with max tire size for the stock 18" x 7.5" rim on 2007 H3X?
Old Oct 27, 2009 | 11:04 AM
I'm no tire whiz, but 18" x 7.5" is a bit different because when you go biger like 315/325s (35") tires, most want a wider rim as well.... some say 8" is the minimum. I did see some 33s that will fit, and I do not see any reason why you could not run 35s so long as you compare the outside actual diameter.
What I saw is most 35s for 16" wheels are a OD of 34.5 or 34.6", but when you go up to 18" wheels, a lot of the same MFGs are at an OD of 34.6 - 34.8. The larger of which might be pushing the envelope just a bit.
I would say look at 34.5-6" or so as your max actual OD tire diameter and you should be fine, most of those are also the same width as the 16" wheel sizes.
Old Oct 28, 2009 | 10:47 AM
northm's Avatar
Thanks for the info. Maybe a situation where 305's make more sense, I'll have to take a close look at those dimensions. The Hummer folks maybe should've given the 18" rim an extra inch in width.
Old Oct 29, 2009 | 06:16 AM
D VADER's Avatar
Just keep the diameter the same. That's can be a wider low profile tire.
bsg424
Jan 17, 2020 10:51 AM
Hummer79
Jan 7, 2013 11:28 PM
rudy_1117
Jun 10, 2009 07:29 PM
schmegeggie
Mar 11, 2009 11:33 AM
IN2deep
Oct 15, 2007 09:23 PM
