AC Low Side Port Location?
Hi, anyone know where the AC low side port is located? I have AC Pro and want to check the low side port pressure and determine if I need to add refrigerant, but I can't seem to find any info or pictures of where the low side port is located.
2007 H3 3.7L 5 Thanks, Jeff |
1 Attachment(s)
good stuff, used it on the wifes ride..
low side is the top port between radiator and engine right side. "larger diameter tube" Attachment 12712 Do-It-Yourself AC Repair, Car Air Conditioning Refrigerant, R134a Freon |
Thanks! That's the one I thought it was. Hooked up the AC Pro and could see the pressure rise and fall when the compressor cycled on and off. Turns out I didn't need to add any, the levels were within limits. I will take some temp readings, but guess that my system is OK, it just didn't feel as cod as it used to, but I could be wrong.
Yes, definitely get a thermometer...
I just checked my temp idling in the driveway, it's 82° outside and 45° at the center console vent.http://fun.resplace.net/Emoticons/Al...assusabeer.gif http://ecx.images-amazon.com/images/...500_AA300_.jpg |
https://cimg6.ibsrv.net/gimg/www.hum...a09fc724b2.jpg
(Post 298759)
low side is the top port between radiator and engine right side. "larger diameter tube" Attachment 12712 Do-It-Yourself AC Repair, Car Air Conditioning Refrigerant, R134a Freon How to Recharge Your Car AC with AC Pro - YouTube |
Originally Posted by threwithu
(Post 346493)
Since that is the only port visible matching the poster's description, that would be a Yes. https://cimg6.ibsrv.net/gimg/www.hum...ab87a1e723.png |
| All times are GMT -5. The time now is 03:29 AM. |
