98 H1 Problems please help!
Old Jan 8, 2009 | 05:37 PM
eindow's Avatar
Default 98 H1 Problems please help!
Hi everyone, Idrive a 98 H1which I recently purchased. Heres my problem, I took the truck off-roading about a month ago and started having problems with it the dayafter.
Here are the symptoms;
Trouble starting.
Idles fine once I do start it, but shuts off the second I try and drive it.
Everytime it shuts off I purge the purge the filter again, only to find air.
When I try to drain the filter it only squirts out abit, then nothing comes out.
Heres what I've tried:
Replaced the fuel filter.
Purged the fuelfilter.
Replaced the lift pump.
Nothing has worked and my patience with this vehicle has become nonexistent. I would greatly appreciate someones help.
Thanks in advance everyone...
Old Jan 8, 2009 | 08:25 PM
hummech's Avatar
Default RE: 98 H1 Problems please help!
sent pm
Old Jan 13, 2009 | 05:47 AM
h1rider's Avatar
hello there.sorry for my bad english.i had the same problem with my 97.i have change the filter sistem and put a toyota land cruiser filter and base(very easy),i did the same with the up lift pump(change 4)now i have a Walbro Marine pump.no more problems.but if i where you i check the fuel pump sensor plug.is a black 4 pins connector just upside the pump.check the pins there because the plug is not goog quality.
samijane
Apr 18, 2014 07:58 AM
rtwash
Dec 13, 2013 10:45 PM
aliciajeanschmidt@gmail.com
Aug 27, 2013 03:42 PM
matelblapav1
Feb 1, 2009 06:37 AM
Patrick
Useless Posts
Mar 6, 2007 09:56 PM
