7 Pin wire harness?
Old Nov 16, 2007 | 06:49 PM
josh1899's Avatar
Default 7 Pin wire harness?
I just purchased an 08 H3 Alpha, but I did not get the Trailering package. I want to get a hitch, and after searching, I found the Trailer hitch FAQ. It talks about the 4 Pin plug, but not the 7. I may tow a few things that require the 7 pin. Is there an adapter or way to have a 7 pin connector with the aftermarket hitch? Any help would be greatly appreciated!
P.S. LOVE the Hummer!!!!!!
Old Nov 16, 2007 | 08:15 PM
blackstangs281's Avatar
Default RE: 7 Pin wire harness?
Any auto parts store will have the adapters you need. You will just need to wire in the trailer brakes.
Old Nov 16, 2007 | 10:18 PM
Hummer Guy's Avatar
an adapter will not give you a true, functioning 7pin -- since a true 7pin has trailer brake power. If you want to add a true 7pin after the fact, you have to get a little box for the trailer brakes in the front, as well as a power line to go from the front of the truck to the back, as one isn't standard if you don't get the hitch. It's a pain, I know..
Old Nov 17, 2007 | 08:24 AM
RealJeep's Avatar
Darn Brian, I didn't know that the stock trailer kit provided power to a trailer brake! See, that's why I read these forums, you learn something new every week.
Old Nov 17, 2007 | 08:37 AM
GM Part numbers if you want to go to a GM dealer to buy the factory type set up:
Hummer H3 Trailer Harness Package 17800532
Hummer H3 Trailer Hitch Wiring Adapter 12496599
Hummer H3 Trailer Hitch Wiring Adapter (Converter) 12497781
Old Nov 17, 2007 | 04:53 PM
Hummer Guy's Avatar
Also remember the factory setup requires a different rear bumper....
thermalfrost
Mar 12, 2014 01:50 AM
ozofoe
Feb 22, 2010 06:18 PM
gregaac
Jan 10, 2009 10:00 PM
bertoy
Apr 22, 2008 03:03 PM
TonyH3
Jan 14, 2008 10:45 AM
