4x4 control lights dark at night
Hello everyone, these forums rule. I searched these forums for
A solution to my problem but I can't find An answer. My 4x4 high and 4x4 high lock buttons are Not visible at night ( there is no light), except the orange Light to me which mode I am in but not the White light. every other thing on the control Panel lights up except these two lights. I can Switch to any 4x4 mode no problem so it can't be anything Wrong with the transfer case. The 4x4 low light Works normally and it dims or gets brighter when I Adjust the dimmer switch. Anybody know what's wrong. Thanks |
lights out....
Make sure your in the furthest to the left button, all wheel high. Haha.
And your bulbs are probably just out.... i did alot of research lately on the dash instrument panel lights, as my center air control knob lights are out... the three knobs are lit up by a tiny bulb behind each, i just ordered replacements in led, ultra violet color hehehe..... i believe i read the other dash items, such as your 4x4 lights, are leds, and maybe only replaceable by desoldering and soldering new ones... no worries, when my bulbs come in within a week, ill have the dash off and ill get to the bottom of these 4x4 lights and let you know the best way to replace them, as i want a bright white or more uv colord ones... ill open them up and see what our choices are for bulb or led replacements... if you can hear your transmission click into the different gears when pressing these your ok, just bulb is out... but make sure your riding around in the furthest to the left... |
bulbs?
probably bad bulbs. its been discussed here,pics,need to solder in i think.
it takes some work and skill to get to them. the bulbs are 12v,.060 amp. if you search you may find the thread that covered this in detail. |
check super bright LED.com maybe there is an LED that replaces the standard bulb
Thanks everybody for the replies. Haha yes
I will make sure that I drive in the furthest left 4x4 option. Thanks again. |
u wanna stick with same type bulbs like the ones that still work/are in the dimming circuit/look the same
Originally Posted by hummie07
(Post 271342)
A solution to my problem but I can't find An answer. My 4x4 high and 4x4 high lock buttons are Not visible at night ( there is no light), except the orange Light to me which mode I am in but not the White light. every other thing on the control Panel lights up except these two lights. I can Switch to any 4x4 mode no problem so it can't be anything Wrong with the transfer case. The 4x4 low light Works normally and it dims or gets brighter when I Adjust the dimmer switch. Anybody know what's wrong. Thanks 06 Hummer H3 4x4 Stability Control Button Switch Factory OEM #1547 | eBay |
thats a steal,,,if just for spare parts
Maybe before you buy anything, just have a look behind there. The bulb in my temp control know has been out for 6+ months adn just the other day I noticed it was illuminated again. I didn't do anything nor have I done anything in the cab of the truck for quite some time so I suspect it may just be a loose connection. You never know.
Good idea - I will probably wait a week or two, hopefully it's just
A loose connection. Thanks |
