-   -   37 tires with stock lift and rims? (https://www.hummerforums.com/forum/private-sale-trade-classifieds-10/37-tires-stock-lift-rims-35460/)
Hummerrican Jun 23, 2015 11:02 AM
Can 37 in tires be installed with the stock ride height?
any rubbing issue??
the tire weight is noticeable during running or off road use?
Synthetickiller Jun 23, 2015 01:15 PM
The ride height isn't the issue. At the worse, you have to crank you keys to provide a little more clearance, but that's it. You may have rubbing at full lock, but it's a vehicle to vehicle thing. Some people have rubbing, others have nothing. It's russian roulette.
Most if not all 37x12.5" tires will fit. 37.5x13.5 or anything that's 13.5" wide will cause problems, specifically in the rear if you have the air ride suspension.
The more weight you add, the less power you have. Granted, it depends on what you're doing.
LoJac963 Jun 23, 2015 11:07 PM
^exactly what he said. Some rigs fit 37's just fine while others don't. I know my stock 35 rubbed on the front sway bar on the passenger side. My aftermarket wheels with a 4.5" backspace fixed that though.
Piranha Jun 24, 2015 08:53 PM
37/12.5/20 fit well on mine with no rubbing:cool:
H2Miami Jun 26, 2015 10:08 PM
Check the align on the sway bar .my does the same and it was 1/2 inch off
LoJac963 Jun 27, 2015 06:49 PM
I'll check that when I replace the end bar links with beefier ones and synthetic bushings. Its not a concern anymore when I changed my wheels.
