37 tires with stock lift and rims?
Old Jun 23, 2015 | 11:02 AM
Hummerrican's Avatar
Default 37 tires with stock lift and rims?
Can 37 in tires be installed with the stock ride height?
any rubbing issue??
the tire weight is noticeable during running or off road use?
Old Jun 23, 2015 | 01:15 PM
Synthetickiller's Avatar
The ride height isn't the issue. At the worse, you have to crank you keys to provide a little more clearance, but that's it. You may have rubbing at full lock, but it's a vehicle to vehicle thing. Some people have rubbing, others have nothing. It's russian roulette.
Most if not all 37x12.5" tires will fit. 37.5x13.5 or anything that's 13.5" wide will cause problems, specifically in the rear if you have the air ride suspension.
The more weight you add, the less power you have. Granted, it depends on what you're doing.
Old Jun 23, 2015 | 11:07 PM
LoJac963's Avatar
^exactly what he said. Some rigs fit 37's just fine while others don't. I know my stock 35 rubbed on the front sway bar on the passenger side. My aftermarket wheels with a 4.5" backspace fixed that though.
Old Jun 24, 2015 | 08:53 PM
Piranha's Avatar
37/12.5/20 fit well on mine with no rubbing
Old Jun 26, 2015 | 10:08 PM
H2Miami's Avatar
Check the align on the sway bar .my does the same and it was 1/2 inch off
Old Jun 27, 2015 | 06:49 PM
LoJac963's Avatar
I'll check that when I replace the end bar links with beefier ones and synthetic bushings. Its not a concern anymore when I changed my wheels.
Caraddict
57
Mar 28, 2018 12:42 PM
Future H2 Owner
Jun 11, 2013 08:09 PM
bhoy27h3
Apr 15, 2009 11:14 AM
importkiller
22
Jan 13, 2008 02:44 PM
magnumoffroad
Nov 28, 2007 06:49 PM
