305-70-16 air pressure?
just had some DICK CEPEK TC IIs put on the h3 the tire shop had the tires @ 40 psi i assume to pop the bead. i lowered them to 38psi but it still rides kinda hard. does anyone know the appropriate pressure or at least the minimum that will still allow the tires to wear even?:confused:
I run my MTZs at 40 on the pavement for a mileage boost. 38PSI cold should be fine, I would not run on the street any lower than that.
Originally Posted by quadblaster240
(Post 212393)
You'll want to keep the tires inflated properly not only for the fuel economy and wear, but the handling/safety if you need to swerve. |
got the same size tires as you on my h3 but MT AT running them at 24psi so as to get a good ride.
it all depends on each tires load range/load index/number of plys,normaly AT tires are built stronger than road tires so are much stiffer,on the mikey thompson site they recommend 70% of the max pressure indicated on the tire. i am probably using more gas this way but i live on a small island !!! |
does anyone have nitrogen in there tires?
| All times are GMT -5. The time now is 10:38 AM. |
