-   -   2008 Hummer H2 loss of oil pressure after warmed up (https://www.hummerforums.com/forum/private-sale-trade-classifieds-10/2008-hummer-h2-loss-oil-pressure-after-warmed-up-38101/)
ferraribuyer Mar 19, 2017 03:57 PM
70K miles 6.2L, has 40 psi oil pressure at cold startup. Within 3 miles it slowly drops to about 10 psi. At idle it will go to 5 and then 0. Light says turn off. If i rev it at idle I can get 10 -20 psi when warm. I changed the oil and oil filter after I flushed the motor. Oil was clean. I hear nothing wrong, no noises in the engine. No rattles or any valve or piston slap noises.
The oil sender is good I would assume since it shows up and down values of oil pressure. I think I have an internal oil leak like a oil pump pressure relief valve or spun bearings? How can I test which one it is without taking the motor apart? A mechanical cause also reads the same and will read 0 psi.
I won't know until I replace the oil pump if its a stuck relief valve. Need some advice.
flyday58 Mar 19, 2017 11:00 PM
6.2 Denali oil pump replacement help / high flow unit? | Chevy Tahoe Forum | GMC Yukon Forum | Tahoe Z71 | Cadillac Escalade - Tahoe Yukon Forum
PIP4158G: Low Oil Pump Pressure Due To Sticking Oil Pressure Relief Valve ? 2007-2013 Buick Cadillac Chevrolet Hummer Pontiac Saab | gm.oemdtc.com
Low oil pressure shut off engine warning
Oil Pressure sensor issues
Been researching because I have two 08s and they're both dropping oil pressure.
ferraribuyer Mar 20, 2017 03:28 PM
probably a main bearing with no noise? Maybe you can do the main bearings with engine still in the truck?
flyday58 Mar 20, 2017 07:42 PM
Still there Enzo? Had my oil pressure sensor changed today. There wasn't a screen installed but they put one in for me. Get it back tomorrow, we'll see how the pressure acts.
ferraribuyer Mar 20, 2017 08:05 PM
that won't help its only for AFM hummer doesnt have that. oil pump pressure relief valve if we are lucky. Did they try do a mechanical oil pressure gauge?
ferraribuyer Mar 22, 2017 05:46 PM
still didn't work?
flyday58 Mar 23, 2017 05:05 PM
Mine is fixed.
ferraribuyer Mar 23, 2017 05:10 PM
no way by putting the filter in under the oil pressure sensor?
ferraribuyer Mar 23, 2017 05:11 PM
You do it for both hummers you have?
tell me more and what to do!!!
