2008 H3 steering wheel/shaft lock (anti theft?)
I have a 2008 H3, jst set it up to tow behind my motor-home and ran into a dilemma... the steering wheel locks when the key is removed. The only way to unlock it is to put the key in Acc, which drains the battery and makes it so you cant lock the doors. I purposely bought a standard to make this tow process easy, never gave wheel lock a thought... dam!!
I have done the transfer case neutral trick, but that doesn't unlock the steering wheel/shaft. Has anyone ever removed the anti-theft steering wheel/shaft lock from a H3?? if so please explain the process. it almost feels electronically controlled by the key removal... maybe there is a coil i can jumper out?? Thank you!! :cool: |
Help!! Anyone??? i would think somebody out there must have had the same issue and has an solution for me....
Thank you!! :) |
I have a 2007 and the steering wheel does not have a lock . They may have changed it in 08 though.
ANYONE???? :confused:
Originally Posted by jst4fun
(Post 283968)
