2004 Hummer H1 - 1 of 21
Old Feb 24, 2023 | 11:36 PM
nkpgarage's Avatar
Default 2004 Hummer H1 - 1 of 21
LOWERED AGAIN. PRICED TO SELL AT $85k
LOWERED PRICE to $95k. Poor thing just sits in the garage unused most of the time. I try to take it out for burgers with the kids once a month, but that's about all the driving it gets.
Motivated to sell. Text or call me if you have any questions, 512-560-8176
2004 Hummer H1 Enclosed Wagon (1 of less than 21)
Total of 252 H1 Hummers built for the 2004 model year
Total of 21 Black HMCS Wagon models built for the 2004 model year
Even fewer equipped with the factory "Off-road Adventure Package"
Asking $129,000 or best offer
My apologies the H1 is not washed and clean in the photos. I will have better photos uploaded when I get time to wash the H1.
If you want a 6.5 turbo diesel equipped H1 with all the newest revisions. + factory equipped e-lockers. + the newer "Alpha" interior that only came on the 2004 & 2006. Then this is the H1 for you.
Unmolested mostly stock with a few tasteful upgrades
Lots of recent maintenance
Ready for many years of enjoyment
Odometer showing 37k miles currently. Odometer was replaced at some point in 2010 based on the factory service sticker at 47k miles. Total actual miles is about 80k.
Includes factory "Off-Road Adventure Package"
  • 12,000lbs Winch
  • 17" 2pc Aluminum wheels
  • Beadlock
  • Factory runflat "donut" built in
  • Electronically selectable electronic front and rear lockers (e-lockers)
  • Factory tow package and 7 pin connector
  • Factory heated windshield
Modifications and upgrades:
  • Predator Heavy Duty Light Bar
  • Predator Locking Fuel Doors for both main and auxiliary tank
  • Predator D-ring Heavy Duty Brush Guard
  • Predator Search and Rescue Fender Well Rack
  • Predator Search and Rescue Center Console Rack
  • Very heavy duty rock sliders / side steps, with underbody protection. I was told these were made by "Blue Hummer"?
  • Very heavy duty wheel "rock guards". I was told these were made by "Blue Hummer"?
  • Predator Polyurethane Hood Snuber Kit
  • 80mil butyl sound deadening on all 4 doors
  • 394mil closed cell foam sound deadening on roof
  • Upgraded high intensity bright LED's in all 3 domelights
  • Upgraded high intensity bright LED's in all 4 reading lights
  • LineX'd roof
  • LineX'd front brush guard
  • LineX'd light bar
  • New soft black headliner
  • New Mickey Thompson Baja Boss tires. Installed properly along with original factory runflat donuts on factory 17" 2 piece aluminum beadlock wheels
  • Frameless 3 button Homelink mirror
  • 10" inch touchscreen headunit with Carplay & Android Auto
  • New OEM stainless steel air filter lid clamp
H1 Hummer updates for the 2004 Model Year that improved over previous years:
  • The all new "Alpha" interior. Much more modern looking and highly desired
  • Optional factory electromagnetic locking front & rear differential (front locker option all new for 2004). This H1 includes both!
  • Upgraded 6.5L turbo diesel engine power was upped to 205hp and 440lb.ft. of torque. An increase of 10hp and 10lb.ft.
  • Full hide leather now standard along with the new "Alpha" interior
  • LED Headlights and LED Taillights
  • Sprayed in and baked in noise absorbing compound onto both the body and key components
  • Improved cargo latches
  • New license plate bracket
  • Improved horn
  • Horn button repositioned to center of new upgraded steering wheel
  • Improved fuel filter mounting
  • Improved and updated door panels, door pulls, and door straps as part of new "Alpha" interior
Recent maintenance:
  • Full "C" Service"
  • Coolant flush and new coolant
  • Replaced all following with new parts
  • New serpentine belt - Gates HD Belt
  • Intake manifold gasket
  • Top ? Shaped radiator hose
  • Gaskets coolant crossover tube
  • Replace all following fluids along with new o-rings/washers/gaskets where requried:
  • Transfer case fluids
  • Front differential fluids
  • Rear differential fluids
  • Transmission fluids, filter, and gasket
  • Engine oil and filter
  • Engine air filter
  • Power steering fluid
  • Brake fluid
  • All 4 wheels Geared Hub Oil
  • Window Washer fluid
  • New windshield wipers
  • Right front hub CTIS spindle air seal
  • CTIS wheel valve x2
  • Turbo air seal o-ring
  • EGR cooler gasket
  • New 180 degree thermostats and gaskets
  • Clean MAF sensor
  • New diesel injection pump and gaskets + timing
  • New rear right OEM window regulator and motor
  • New right side curved OEM mirror glass
  • AC system pulled full vacuum and recharged. AC & Heat both working and holding charge properly
  • New transmission 1-2 shift solenoid
  • New transmission 3-4 shift solenoid
  • New transmission TC solenoid
  • New transmission internal solenoid harness
  • New transmission TCM + factory programming
Things to note
  • ABS light is on due to the common issue with the ABS "shuttle valve". Brakes work fine, but ABS is disabled until this is fixed. Repair kit part number SWO500030 required for the fix. Land Rover part, about $90-120.
  • Low coolant light is on. Needs a new low coolant sensor. Part 6008600. Available from hummerpartsguy.com for $249
  • Driver side windshield has a crack in it. I have a replacement OEM heated glass windshield along with new OEM gaskets to replace it all in boxes. Will include in the sale.
  • Predator Hood snubbers currently on the truck are fine, but I have a new set in the box that I was going to install. I Will include these
  • Not installed, but included is an original OEM stereo if you want to go back to the original
  • This is beautiful 2004 Hummer H1. It is 19yrs old and in great condition for its age. But it is still 19yrs old so it has little flaws here and there. Please ask any questions you have and I will do my best to answer them. With a few little things addressed this is easily a $150k H1. I am asking $129k or best offer.
Old Feb 24, 2023 | 11:37 PM
nkpgarage's Avatar
More photos:
Old Feb 27, 2023 | 06:42 AM
Definitely could use a clean-up. Might be doing yourself a dis-service posting these pictures. Steering wheel shows a lot of wear, they aren't that expensive to replace. Wheels show rock rash and paint shows some brush rash. For your asking price you should look into getting some of that cleaned up. 2004 had the CAT controls. Only year for that so not every H1 mechanic will be good with trouble shooting the electronics. You have done a nice job adding to the truck. Prices are high on H1s. Adding all of the HMMWVs to the market has not hurt H1 prices at all. Good luck with your sale.
Old Feb 27, 2023 | 02:22 PM
nkpgarage's Avatar
That's great feedback. The wheels just have some clearcoat that is starting to peel off, but no rock rash, might be the photos. I just took a look and you're right, steering wheels are readily available. Just ordered a new one along with the hub for a couple hundred and will be installing it. Hope to have some time to clean it up in the next couple weeks and take fresh photos. Work is very busy these days.
And I'm open to offers :-)
Old May 27, 2023 | 01:59 PM
Tnbusiness71's Avatar
I am interested. What’s the mileage? Please DM me. Seriously interested and have been looking for some time now.
Old May 27, 2023 | 06:08 PM
nkpgarage's Avatar
Just sent you a message with my contact info.
Old Aug 22, 2023 | 02:10 PM
nkpgarage's Avatar
Lowered price to $95k. Poor thing just sits in the garage unused most of the time. I try to take it out for burgers with the kids once a month, but that's about all the driving it gets.
Old Aug 22, 2023 | 02:11 PM
nkpgarage's Avatar
Some recent photos
Old Aug 26, 2023 | 05:37 PM
nkpgarage's Avatar
Lowering price to $89k if not sold in the next few days. Message me if you are interested.
Old Sep 3, 2023 | 09:02 PM
nkpgarage's Avatar
Lowered price to $85k
