08 H3 - Installing LED in footwell - need help
Old Feb 11, 2014 | 02:35 PM
atari800's Avatar
Lightbulb 08 H3 - Installing LED in footwell - need help
I am trying to install LED bulbs into the front footwell of a Hummer H3 2008. It appears the bulb is not replaceable. I could be wrong. It appears that the bulp is housed into a plastic connector and the 2 wires lead way up into the dash. I guess I could snip the wires but.....
Is there a guide to replacing these bulbs, a trick?
I know relearning the TPMS sensor requires a dance around the vehicle, but I would think replacing a footwell bulb would be a push-twist event.
Any ideas?
Thanks in advance
/|\tari800
Old Feb 12, 2014 | 09:18 AM
atari800's Avatar
Well, I ordered:
Install Bay Quick Disconnect Male Nylon 22/18 Gauge .250 - 100 Pack
Amico Car Truck T10 W5W 194 LED Light Bulb Socket Holder Wire Connector 5 Pcs
Install Bay 3MRTT T-Tap 22/18 Gauge, Red 100 Pack
iJDMTOY 12-SMD 168 194 2825 T10 LED License Plate Light Bulbs, Xenon White
With these I can wire tap high up the footwell lamp wires, add male connectors to sockets and plug into the taps, plug in LED, and put into place.
If it looks acceptable, then I can try to cut the wire to the OEM lamp and see if any crazy Hummer alert triggers
If it does, I can reconnect wire
If it does not, all is good
Stuff should arrive on Thursday, so I could have a report back here by the weekend - depends on weather
Old Feb 14, 2014 | 05:22 PM
SolidJJ's Avatar
6 LED's altogether and about an hours worth of work.
[URL=http://s1183.photobucket.com/user/solidusj/media/DSCN2473_zps84f67067.jpg.html]
Old Feb 15, 2014 | 08:39 AM
atari800's Avatar
Very cool. I should have done that (multiple LEDs ) . I just wire tapped and added the addition bulb and tucked it in the wired mess up under the dash. So I got the original build and led working together, but the led outshines it.
My camera does not show the LEDs effects.
Maybe I can borrow an iPhone and take pics
Old Feb 15, 2014 | 11:26 AM
SolidJJ's Avatar
You can upgrade down the road, pick up some LED strobe light kit off amazon and just made a harness and linked it to the OEM foot light, orange positive and white negative.
Old May 20, 2014 | 06:41 PM
e0308jr's Avatar
So you picked up a strobe light kit and didnt use the control box and wired them Directly?
Old Aug 8, 2015 | 08:09 PM
Warriorking60's Avatar
The bulbs do come out. I had to use a small jewelers screwdriver. But they do come out.
Old Aug 31, 2015 | 06:10 PM
650Hawk's Avatar
Yup; they're just standard wedge style bulbs. I replaced mine with LEDs. They were a bit tight, but after wiggling a bit, they unplugged.
justin67
Dec 18, 2010 01:12 PM
DHolli
Feb 23, 2010 06:23 PM
jimmylee7706
Sep 16, 2009 01:19 PM
trigag92
May 14, 2008 07:41 PM
efrainl956
May 16, 2005 10:46 PM
