How to replace cabin air filter
Hi Guys, I just find out this video on how to replace cabin air filter. Its relatively simple repair that can be done in a few minutes. I just don't know if that will work for hummer? Any suggestions? Thanks.
If your Hummer has one it's inside the H2 on the lower portion of the right side dash. The filter sits verticle.
The H3 doesn't have a cabin filter. :(
The only filter that the cabin might have is probalby in the fire wall where the blower motor gets air from
Replacing your car's air cabin filter is a relatively simple:
1. Remove the main access cover, undo the cover fasteners to remove cover and side cover if needed. 2. Locate and undo retainer clip to remove air cabin filter, compare the filter size to the replacement filter and reassemble. |
Originally Posted by zombiember
(Post 213085)
I am a non-smoker. The filters were pretty clean at 30K miles. You could hold them up to the light and see quite well through them. In fact I've set them aside for possible re-use.
The climate in New England is not very dusty and there are few gravel roads. I was not having any problems with feeling the AC, either. The reason for erring on the side of preventive maintenance was concern over getting my allergies riled up. A friend who has a Subaru shared a similar story about his cabin air filter. |
Thanks to acai berry juice, after 41 years, I'm no longer a smoker!
Originally Posted by KineIntiz
(Post 217420)
Originally Posted by jurelut
(Post 213892)
