Dear GM Engineers
You wonder why people buyimport cars instead of yours? How about because it's easier to change a damn freakin' light bulb on an import then it is on a H3.
Why in the F would you design the frame so that you have to spend 20 minutes taking off a damn wheel well cover just to take 30 seconds to change a light bulb, then hope you can actually get the thing aligned right and take another 10 minutes to get them back in, all because your turn signal went out? Then, you make the turn signals driving lights, but don't use long life bulbs? Real nice. So, I just spent about an HOUR to research how to do it, figure out where all the damn plastic pop nails are, and spend 30 seconds replacing it and the driving light. Or, I can just take off the front grill, take the light assembly off and do it that way.................... Why on Earth would you do something so stupid? PLEASE, I'd REALLY like to know [:@] Nice try at making me spend $85 to take it to the dealer to get a 99 cent bulb replaced. morons..... :eek: |
RE: Dear GM Engineers
Think thats bad? Try changing the headlight bulb on a 2003 C320, Mercedes doesnt have a plug in type bulb it has to be secure with some stupid metal clip that is impossible to get off let alone back on, I spent 4 hours changing mine when I had that car.
That's rediculous. I don't feel so bad about my hour now :eek: This is my 12th car, and this must be the most rediculous setup for lights I have seen...
well, heard of, now that you told me that :D |
No its completely horrible, and all the manual said was re fasten the clip
They are having coffee at the Tech Center right now smiling. :DThey know about you Mike, :eek: they knew you would have to change that bulb and designed the whole H3 around making things difficult for YOU just for the sake ofpissinYOU off. [:@]
Did it work? :eek: |
I think so....
I read his LONG post several times now and still cannot figure out which light/bulb he is bantering about????? Trun signal v side marker....? [&o]
Me either but I get his point,
I think he means the front turn signal by the headlight. Because if he is taking off the front grill to get to the side marker light than he's going about it all the wrong way.
hmmm...took me about 10 minutes to change out my headlights and signals....never took anything off....
