Turbo or Super
Old 08-03-2007, 09:25 PM
GorillaH2's Avatar
Default RE: Turbo or Super
ORIGINAL: ttkresurfacing
I have the Magnuson radix supercharger and wouldn't change it for the world. Not only is it a hell of alot more fun to drive but I picked up 2 mpg too.
Tim
Tim could you give me a link and how much horsepower does it offer?
Old 08-06-2007, 09:00 PM
Bob,
I had it painted to match my truck, so not too shiny. Did get all the brackets chromed though.
Gorilla,
Here is their site and install pdf. www.magnusonproducts.com http://www.magnusonproducts.com/pdf/manual02.pdf
I have the s/c, Allen Nelson tuning, ceramic coated headers, throttle body bypass, Airaid cai, and Gibson exhuast and dynoed @ 508 at 6lbs. boost in 75-80 degree weather. Getting ready to go to 8lbs., 90mm throttle body, LS7 Z06 cam, 918 springs, and methanol injection should put me over 600. Trying to find someone that can change this thing to selectable 4 wheel drive with the new Allison 6 speed.
Tim
Old 08-08-2007, 07:51 PM
GorillaH2's Avatar
Thanx for the links and I might buy the magneseum supercharger and the numbers look legit though 6lbs of boost makes 508hp that seems high for that little boost. BTW what is the most boost an H2 can handle without it being dangerous because I seen little v6's with 20lbs of boost on pump gas. Hope I'll get the same results as you.
Old 08-08-2007, 10:34 PM
I was told not to go to 10lbs. I am gonna be at 8lbs. soon so I'll give you an update. If you do get one, if you are looking for performance then go with Nelson or compatible tuner not the one that comes with it. I believe that alone is around 30hp.
Tim
Old 08-08-2007, 10:35 PM
Old 08-09-2007, 10:57 AM
GorillaH2's Avatar
I had a problem with ebay a few months back, cause i lost about 6k on a turbocharger for my viper and it was cracked. I never use ebay for anything over one $1000 because I dont trust it.
Old 08-09-2007, 08:05 PM
If you want to find a decent used one try www.performancetrucks.net. I got mine off there for $2000 in like new condition. It will be the same unit as for a Chevy truck and you'll just need like the intake tube and a few other things.
Tim
resqur
11-30-2006 08:07 PM
rod
08-08-2006 12:31 AM
hummer plumber
07-20-2006 09:43 PM
rod
03-27-2006 11:05 PM
Dennis
03-13-2006 10:23 AM
Quick Reply: Turbo or Super
