Nightmare
Old 02-08-2018, 05:51 AM
budbroker's Avatar
Default Nightmare
2009 H-3------ Starts / runs fine, the issue is after starting if you don't put in drive quickly the shifter will lock in Park. Also wipers, auto setting lights go out. Radio works.
All the dash indicator lights, battery, TPM, etc, flash.
It will eventually correct itself and all is good, usually a few minutes but it has lasted 30 minutes.
Any ideas?
Old 02-08-2018, 06:06 AM
Sunroof? Is the passenger side carpet wet under the mat?
Old 02-08-2018, 06:39 AM
budbroker's Avatar
I have had that issue but not wet for months
Old 02-08-2018, 08:10 AM
Welcome to HF.
That means 99% sure that your PCM got wet = electrical Gremlins.
Fix the problem before getting a new BCM.
https://www.hummerforums.com/forum/h...n-tubes-28548/
Vids: https://www.google.com/search?q=humm...bih=1069&dpr=1
Do you still have the OEM POS Battery Terminal Connectors?
drmeek
02-06-2020 07:09 AM
ezekielj007
03-13-2015 02:09 PM
AR15wheeler
03-10-2015 01:48 PM
drtom
11-23-2010 02:08 PM
beachman
18
09-25-2006 06:43 PM
Quick Reply: Nightmare
