New To The Froum
Old Feb 24, 2025 | 01:22 PM
jbon007's Avatar
Default New To The Froum
2003 H2 battery parasite draining my battery in 2-3 days I have taken it to two differant mechanic shop and they can find nothing /replaced with new battery no change,pulled fuses,pulled onstar no add on other then a back up camera..disconnected that also .any help would greatly be appreciated.thx
Old Feb 24, 2025 | 02:12 PM
Welcome to HF. This section is strictly for intros so you can post you questions on how to find a parasitic draw in the H2 section.
I would suggest you search that topic here at Hummer Forums using the search bar in the upper right hand corner. The short form is, put a voltmeter on the battery positive side, look at the reading, start pulling fuses and check the reading after each one looking for when the draw stops or changes.
These trucks are OLD, check that all the grounds are clean and corrosion free by taking each one apart, cleaning with a wire brush and/or Dremel then a shot of CRC Electronics Cleaner.
Old Feb 25, 2025 | 05:32 AM
Welcome to HF
Old Feb 25, 2025 | 09:27 PM
Welcome
Old Feb 26, 2025 | 07:28 AM
BLK WLF's Avatar
Volt meter and pulling fuses.
Did you disconnect onstar only or did you pulled the fuse?
Btw, welcome to be hummerized!
Old Feb 27, 2025 | 05:28 PM
Jahtrue's Avatar
Welcome to the forum
Shantilreid
Nov 7, 2022 08:11 AM
dougie
Jun 22, 2020 01:13 PM
dougie
Jun 20, 2020 02:21 PM
mnext02
Jan 7, 2012 08:43 PM
HammerDown
21
Feb 19, 2008 07:04 AM
