H3 power sunroof problems
Anyone help .. I have an h3 2006 model ... All of a sudden the sunroof wont work.. Switch is clicking but no movement. Does anyone now if there is a resett for the sunroof anywhere ??
Any help please .. Cheers ian england ...
I had never really thought about this one but is there a way to manually move it back into place? Years ago you could manually crank if the motor dies....that would really suck if you were wheeling and a big rain cloud appeared...hmmm...would like to see if anyone had a fix for this other than garbage bags and duct tape.
Replace fuses ...
Yes i checked the 30amp ... But not the others good idea .. I didnt know about the others manyy:d thanks i will check the rest in the morning thanks again .. I will let you know about my progress .. Thanks for your help .. Cheers ian ..
Power sunroof ...
YES ALL FUSES AND RELAYS ARE ALL OK .. AS I SAID THERE IS A CLICKING COMING FROM THE SWITCH INSIDE THE CAR,, SO THERE IS POWER GETTING THERE OK.. ?? STRANGE .. IS THERE A SWITCH INSIDE THE CAR THAT MIGHT OF TRIPPED OUT MAYBE ??.. OPEN TO IDEAS.. THANKS IAN UK ..
Sun roof fixed.. Sometime in the past the dredded water leak has got into the roof motor and seized it .. Some oil and a little time .. Problem fixed.. Thanks for all your help. I hope this helps others .. Cheers ian uk ...
Take a look here: https://www.hummerforums.com/forum/n...bumping-23220/
