Help!!!
Old 05-13-2018, 03:12 PM
Default Help!!!
My h3t is having some issues. It is getting stuck in park, I know how to release, but also it now has stability failure and check engine lights on dash, also speedometer is not working and running high rpm with low output?!?
Old 05-14-2018, 12:09 PM
Miles on the truck, any recent work?
Have you checked the T Case speed sensor and its wiring connector and harness? Same thing with the T Case encoder motor for range selection.
Old 05-14-2018, 02:18 PM
miles 73500. Recent work...new CV Axel wheel hub calapers rotors and pads...
Old 05-15-2018, 01:35 PM
Get the codes read and post them here.
STAB FAILURE is probably one of the ABS sensors (you had a hub replaced).
Key stuck can be the neutral safety switch under the console gear shift lever.
Speedo is what Doc said to check
importkiller
Off Topic
29
01-15-2008 02:51 AM
Quick Reply: Help!!!
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
