H3 making horrible noises
Recently My H3(178k miles) has been eating oil like nothing (no sign of oil leak) and a terrible knocking under the floorboard (not caused by the suspension) it sounds like the drive shaft is dying. when you open the hood the engine is vibrating. When a guy opened my hood while my H3 was on, he said "this s*it is f*cked up" basically this H3 is problem filled! If I pull up on my button to raise my window the lights dim.... If anybody has any idea or common issues with the H3, please let me know. I hate to Let It Go... But I'm going to have to get a new car this thing sounds like it's going to blow up! And coming from 30 to a stop the car struggles to downshift.
When was the last time the Trans fluid and filter was changed?
When was the last time the Transfer Case fluid was changed?
When was the last time the MAF was cleaned?
When was the last time the Throttle Body was cleaned?
When was the last time the spark plugs were changed?
When was the last time the front diff lube was changed?
When was the last time the rear diff lube was changed?
Are you still running the original U Joints in the front and rear drive shafts?
Please, let me get this straight.
No regular maintenance on a 178,000 mile approximately 10+ year old vehicle and you are complaining about it having issues? No vehicle, regardless of make/model will last without regular maintenance and wear items being replaced over 150,000 miles.
You would like someone in the internet to diagnose all of these issues with some vague description of multiple issues with the above described vehicle? Doc asked specific questions which you answered with a canned response about fluids. Only 4 of the 7 questions had to do with any fluids.
Let me get upon my rose farting unicorn while I gaze lovingly into my crystal ball and get back to ya...
dartdart
11-04-2014 06:19 PM
Dirtman2009
12-16-2009 10:08 AM
baffa
32
09-17-2009 11:51 AM
Nick119
52
07-21-2007 01:53 AM
