H3T Bed Capacity???
Need to pick up some gravel. Does anyone know how much in lbs i can carry in the bed. I'll have to get 1.7 tons for a shed foundation.
Originally Posted by tlh235
(Post 314634)
2 tons is 4000 pounds!!! yikes,, a little much,,make a few trips huh.
a reg h3 is over loaded with 4 big guys,,go figure. maybe the book tells huh? |
I believe I had 1 cubic yard in the bed which was 1.4 tons? This was a few years ago.
1 Attachment(s)
Payload on the H3T is 1/2 ton, 1080lbs to be exact.
I have way over loaded the bed with 1500lbs (.75) tons and it was riding on the leaf spring bumpstops. I only went 3 miles to get home. I wouldn't recommend it for anything longer than 5 miles. Same as your truck with 1500lbs in the bed, WAAAYYY over loaded! Attachment 12025 Spend the extra $ and have the 1.7 tons delivered. Save your trans, brakes and springs. |
I think you should get it delivered as well.
