H3T 3.7L 5cyl wrong fuel pump
Just wanted to warn everyone that Bosch lists their 67791 as fitting the 2009 3.7L 5cyl. It doesn't. I will report back when I figure out what does.
:mad: |
try ACDelco, right part, right fit. needs a updated pigtail too
Originally Posted by sycraft
(Post 347637)
Edit: I don't see any related part listed. |
may be ok, will come with pump if needed
How many miles on the old pump before it stopped working?
Originally Posted by woodwardsh3
(Post 347670)
I thought I would try something different this time. Usually I'm the one in the high mileage vehicles and I ignore all the warning signs waiting until it has a full tank and is stuck on the side of the road somewhere. Factor in RA showing only 2 ACDelco pumps left I thought a would just take care of it before winter sets in. |
2 Attachment(s)
This is the Bosch 67791 with the screw in fuel fitting that did not work on my 3.7L 5 cyl H3T. Bosch lists it as compatible, so all the vendors do as well.
I selected it for the metal lid and the Bosch reputation. If the pictures provided by ACDelco were better, I might have noticed they were different. |
3 Attachment(s)
This is the ACDelco MU1879 that did fit my 2009 5 cyl H3T. There were no issues with the electrical connectors that SYCRAFT suggested. Everything plugged straight in and the truck is running noticeably better with stable fuel pressure as an added bonus.
Note: This is a protective shipping boot over the fuel line connection if that is not obvious to you in the picture. |
My truck has a March 2009 build date. Anyone that has replaced the fuel pump please post the build date from the door sticker, engine and whether yours had the screw in fuel line or the vertical quick connect. As GM lists only one part number for all years H3T, I am curious if this is engine or build date related.
