Encoder/ actuator motor replacement
Sorry I’m new to the hummer what do you mean by 4 high unlock right now it currently won’t move out of that standard all wheel drive mode when I push the for high button it just flashes if I reset it for the code reader it will let me put it in if I’m in park
Why the Funk would you need the transmission in neutral!!!!
I read about some guy with a spinning spider monkey on his dick but I used "common scene" and did not do that either.
The transmission is an independent entity of the transfer case. Set the Tcase control to 4 HI unlocked, turn off truck, disconnect battery, block at least 2 opposite tires, crawl under the H3, remove the wire connector to the encoder, remove 3 bolts on the encoder, replace the old encoder with new encoder. install 3 bolts back into the encoder, reinstall the harness, reconnect battery, turn key forward, test the new encoder by switching from 4 HI unlocked to 4 Hi Locked several times.
If you are not sure what 4 HI unlocked is you shouldn't be replacing Sheet on your H3.
If you can NOT get out of 4 HI unlocked, it's probably not the encoder. It's going to be a shift fork issue 90% of the time.
Thanks tainter I was just getting mixed answers from different people in different forms putting it in neutral not putting it in neutral leaving and park yours is the best answer and I really appreciate it I thank you very much only reason I have a question on the four high on lock was whether or not to actuate the switch or manually put it in for high once the encoder motor was out it will go into 4high once I start it and I push the four high button but it will not do it on the fly
Keep in mind that the H3 transfer case will not switch from 4 HI to 4 HI Lock (or back) if you are driving faster than 45mph.
I just get frustrated with all of the bad and incorrect information on Bookface/social media. No forum said neutral.
Please, use punctuation. It's very had to know when a sentence ends and a new one starts.
"If you can NOT get out of 4 HI unlocked, it's probably not the encoder. It's going to be a shift fork issue 90% of the time."
